Default Settings
The Aranet Radon One sensor is calibrated in the factory, and it works instantly when it you take it out of the box and insert the batteries – no additional setup is needed. These are the default settings of the Aranet Radon One sensor:
  1. The default radon measurement units are set to Bq/m3;
  2. Bluetooth connection is enabled;
  3. Bluetooth connection transmission range is set to normal;
  4. The buzzer for audio sound alarm notifications is disabled;
