Aranet Home App Overview
The Aranet Home app is the companion mobile app for Aranet’s indoor-environment sensors (like Aranet4, Aranet2, Aranet Rn+, Aranet Radon One and Aranet Radiation sensor devices).
Compatible with both iOS (iPhone / iPad) and Android.
Using the app, you get a convenient hub for monitoring, configuring, and analysing data from your sensors. Key features:
Real-time readings — view current measurements (CO₂, temperature, humidity, atmospheric pressure, and more, depending on the device).
Measurement history & data storage — you can store past measurements (history) and review data over time. The app supports up to 90 days of history (depending on the device and its settings).
Customizable measurement intervals — you can set how often the sensor measures and sends data: 1, 2, 5, or 10 minutes.
Charts & data visualisation — the app turns raw sensor data into easy-to-read charts and colour-coded visuals, so you can spot trends (like CO₂ spikes, humidity swings, etc.) over time.
Export data — you can export stored data (e.g. CSV or XLSX), which is useful if you want to analyze data elsewhere or keep long-term logs.
Device configuration & management — you can pair/unpair devices, update firmware, adjust sensor settings (e.g. measurement frequency, CO₂ threshold levels, buzzer/alert settings), rename devices, etc.
Widgets — on supported mobile devices you can add app widgets for quick-glance values without opening the full app.
Smart alerts / Notifications — the app can notify you when certain thresholds are exceeded (e.g. CO₂ levels go into “unhealthy” range) or if the battery is low (for battery-powered devices).
Also, the app supports multiple languages (English, German, French, Latvian, and more).
